Discuss Change single socket to a double in the Australia area at ElectriciansForums.net
M
Mattbot2
Hello,
I have a single socket in the corner of my bedroom, i would like to replace this with a double socket. Can anyone advise me on how i would go about doing this?
Thanks,
Matt
plug in an extention lead matey its easier;)
I'm unable to do this as i plan on using homeplugs. Homeplugs are for computers, they send data across your houses electrical lines so that it is essentially wireless. These get interference when used in conjunction with a surge protector, as i am using.
Hello,
Thanks,
Matt
Unless you are know what you are doing leave it alone and get an electrician in to do it.;)
A little knowledge can be DANGEROUS.:eek:
You can get sockets that double up (or more) called converters that you change your existing socket for. No chasing to do.
1G to 2G Sw Skt Conversion Kit - NoLinkingToThis, Where the Trade Buys
However, you should be competent in doing this type of work. If not call in a sparky.
Have a look at these
http://http://www.NoLinkingToThis/prods/12849/Electrical/Switches-Sockets/Socket-Converters/Clipsal-Converta-Skt-1G-to-2G-Polycarbonate
Which one of these two should i get?
Pay your money, take your pick. Go to screw fix and have a look at them. If you have any doubt about fitting this contact a electrician.
hate them stoopid plugs.half of them fail early, and the other half never pair easily. don't use wireless if I can help it.
cant beat good old fashioned cabling.
my whole house is dater cabled up... 48 port patch panel with 40+ outlets across the house in every room.
makes future upgrades a doddle :)
and lovely gigabit LAN speeds :p
Reply to Change single socket to a double in the Australia area at ElectriciansForums.net
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Hi all. I'm going to replace some sockets during a routine redecoration of our lounge including replacing some singles with doubles with USB...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
If someone made a request to you, to install a new double socket that would be supplying power to a tumble dryer along a circuit that does not go...
