Discuss Earth Rod Connectors in the UK Electrical Forum area at ElectriciansForums.net
WallaceP
ok, so stupid question. its been a while since i have used any earth rods, and the first time since i was an apprentice that its for a tt system and not an earth ref for a generator. So iv got my rods in, and im going to connect it up but i have split the connector, two of them in-fact, i wouldnt say i over tightened it as the earth wire wasn't secure yet. I must be doing something wrong but im not sure what. does anyone have any advice. The original clamps i broke were like the attached photo, i am going to get the u bolt style next time to save what is left of my pride :(
That's a G clamp if you've broke two of them in a row it could be a manufacturer defect. I would recommend manufacturer Furse either a GUV clamp or B clamp. The latter will require you to crimp a lug onto the cable.
Thanks, I am going to come back and fit a b clamp and put an earth pit in next time i'm round. Should there not be a notice on the clamp saying 'safety connection do not remove'? I was thinking of stealing one from a pipe clamp and cable tying it to it.
Reply to Earth Rod Connectors in the UK Electrical Forum area at ElectriciansForums.net
Afternoon all I am looking for some advice as on what to with the suppliers earth after a conversion to a TT system. Current issue is earthing...
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
Hello, 1st time post from an amateur. I have some old Habitat decorative lights that are powered by a transformer. There seems to be a break in...
Hello All I was pondering an idea recently regarding the ground connection to my property. At present it has a combined Neutral to earth at the...
