I have replaced consumer unit in small rented property, on pre visit found everything fine. Replaced,tested all the circuits, all sound, issued eic.
For letting agency eic is not enough, Eicr is due now, and they wouldn't accepr Eic instead, are they right?
Thanks![]()
eicr due to 5 years period, consumer unit swap due to being plastic, faulty rcd, cracked case and generally client scared of fires..What is the reason for this now being due ?
its all ok guys, most of you answers are quite obvious to me, but taking into account landlords rules, are they allowed to keep eic (board change, no comments, installation sound, inspected and tested) in records instead of eicr that is due?
5 years eicr on the cons unit stickerWhy is it DUE ?
You are also advised to do an EICR Prior to board change.
y years eicr on the cons unit sticker
[automerge]1597347425[/automerge]
no, board been changed just now, at the same time as 5 years eicr is dueIf it's been five years since the board change then I think an EICR request is reasonable and works with the letting rules. It shouldn't be seen as a bad thing it should be applauded.
