C
CSL
You can probably tell, I know nothing, so reply as if talking to a five year old (sweets and pats on head excluded).
I have two heaters from what I can make out. Downstairs a wall mounted non storage heater in our utility room. Upstairs a more conventional electric water boiler with old fashioned orange foam insulation.
I recently had to cut off the water supply to the house whilst fixing a corroded radiator feed. I switched off the electric switch on the upstairs boiler prior to doing so but once everything had been fixed, I tried to switch this back on but the light on the switch stays off.
I have some hot water from our downstairs unit, but this is not as before where we had copious amounts of hot water.
Is it likely that I have somehow tripped something internal with the boiler (Big thing covered in orange foam).
that switch for the boiler is most likely a FCU ( fused connection unit) and will have a fuse next to the switch. usually it's a 3A or a 5A. might have blown. flick carrier out with small driver, or if it's MK, you need to unscrew the samall screw that holds it in.
Electric light on boiler off. Fuse box shows no tripped circuits.
Central Heating Systems
CSL,
telectrix,
