What are your thoughts on using electric underfloor heating as a primary heat source in a church?
It's a typical old church building - a couple of hundred years old, very high ceiling, masonry walls, single glazed stained glass windows, no insulation anywhere. You know the sort of thing. Cold, and difficult to heat. The wall heaters aren't very effective, as the heat just rises up away from where it's useful.
The church representative suggested UFH, the idea being that it would produce heat where it's needed most. The church is used sporadically, so it wouldn't be heated all the time, just when needed.
Just wondering what you all think of the idea? Has anyone here done the same, or heated a similar space using UFH? What about warm up times, and efficiency?
A Church I work for had all the old radiators removed and 2 air conditioning units installed that heat in the winter and cool in the summer.They certainly warmed the place up and that had very high ceilings.I cannot see UFH working in such a large area.
The old biddies will think Hell is creeping up to them from underfoot….
Many of the churches I’ve seen are tubular heaters under the seats, and the occasional panel heater in smaller vestry rooms.
Having a heat pump and water underfloor heating can work quite well in terms of comfort and running cost (within reason) but it is not a cheap installation.
Was once holidaying in some converted fishing cottages far north with that and amazed that I was not bloody freezing as I expected to be!
Edit: Was here:
The IR radiator sort might be good as they offer "instant warmth" before air has to heat up, etc, so if church used only for short periods at a time more economic.
But longer use a heat pump, either for UFH or air-con working in reverse to heat (as suggested above) is going to get more therms per £ than other methods.
Hmm, all electric heating in that sort of building - I can't help thinking it might be just as cost effective as getting a load of fivers from the bank and burning them in a brazier 😱
We have a wet system that's been cobbled together over time - starting with the old cast pipes down both sides, and most recently with some fan coils added. It takes the boiler half an hour just to get the (guestimate) 100 gallons of water in the system up to the point where the pipe stats in the fan coils come on.
As they were installed, the fans were far too noisy, so at the start of the service they'd be switched off. At this point, the water in the pipes isn't hot enough for them to do all that much, and the cold draughts coming down off the windows made everyone cold rather quickly. We've done some experimenting, and by changing the stats for a higher temperature, and fitting resistors to give an extra-slow speed we've just about got it to the point where they can stay on and the place isn't too bad now. But it's still expensive to run (oil - no mains gas) and I'd hate to think how much it would cost to heat by electric.
UFH is definitely the way to go in terms of heating, but direct electric would probably be the last choice for running costs. Mains gas & condensing boiler would probably top the list, followed by a heat pump - both wet systems. Oil or tank gas probably still come higher on the list than direct lecky.
BTW - one advantage of wet system is that they are limited in temperature to the temperature of the water going round. If someone puts a rug or carpet down on part fo the floor then that bit of floor can't overheat. Electric is constant energy - if you insulate part of the floor with carpet or furniture, then that part will get hotter (potentially a lot hotter) unless you have self-regulating elements.
Wet system, pipework and rads sited correctly is the best thing for a church in my opinion.
Maybe a couple of Myson low line fan convectors on a separate zone (drop out prior to service).
Infrared wall heater in transepts or other small rooms/areas that might be used on occasion or for small gatherings etc.
I agree, that's probably about the best option for retrofit. If the opportunity arises, UFH (wet), possibly in combination with rads if needed for total heat output gives the advantage of not leaving the feet as cold.
But whatever goes in, churches are usually a p.i.t.a. (and expensive) to heat.
Thanks for all your comments on this, I'll pass on the info to the church representative.
This might be a better idea than UFH for a church: I recall seeing these at a Christmas market in Berlin years ago, you paid a euro and got 10 minutes or so in them to warm up. (not my photo, stolen from the web)
Warwickshire
United Kingdom
Electric underfloor heating for a church?
Electric Underfloor Heating Wiring
Pretty Mouth,
UKMeterman,
