Discuss Emergency circuits in the UK Electrical Forum area at ElectriciansForums.net
Cookie
Ok, say you had a building that needed backup power. Does British Code require that the loads be subdivided onto different branches and automatic transfer switches based on type and priority?
Ie, NEC forbidding:
Edit:- Copyright material removed... please post a link to the original source material. Thanks
Reply to Emergency circuits in the UK Electrical Forum area at ElectriciansForums.net
Hi I'm in need of some advice. First of all i'm not an electrician but do have an understanding of electrics as i come from an electronics...
Hello Forum! The building I maintain has some fluoro fixtures with battery backup ballasts. There is a 3-way switch at each end of the hallway...
For power outages, my solar inverter (+battery) is able to take on the entire house load - as long as I unplug my collection of vintage kettles...
I need to handle power failure for my electric strikes in my house. Of course, I can leave the keyed entry on the knobs, but what if I wanted to...
