Discuss Enclosed light fitting and extending circuit in a bathroom in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
S
sparky200
A couple of questions that have bothered me since 17th came in which I would appreciate comment on.
Firstly if I replace a battenholder in a bathroom with an enclosed light fitting and and cross bond to nearest water pipe do I need to ensure that the lighting circuit is RCD protected.
Also if I install an low voltage fan with transformer and isolation outside bathroom but off the lighting circuit do I need to provide an RCD.
Many thanks
Sparky200
is the pipe already bonded then? does the light fitting have an earth already? in that case you dont need to "cross bond", or supplementary bond the pipe. if the pipe has no bonding, then either your main switch needs to be an RCD or you need to install some main and supplementary (see your regs).
That used to be a simple no, but now pretty much every circuit (with a FEW exceptions) should be RCD, I go off the premise that if I'm not sure, bang one in.
Sorry I cant be more definitive.
If the fan isolator/transformerr are surface mounted external to the special location,the low voltage fan mounted in the special location No supp bonding or rcd required
The enclosed light replacing the baton holder it is replacement work only if it is still a class 2 fitting,again no req to rcd the lights
Isn't it the case that - apart from maintenance such as replacing the light fitting - you shouldn't alter or extend a circuit unless it is 17th Ed compliant? ....
i.e., RCD protection a definite requirement for all circuits passing through a room containing bath or shower, and supp bonding the not required if the three conditions met (extraneous part continuity to MET confirmed, 30mA protection, and disconnection times met).
Or am I missing the point here? (Quite likely!)
Reply to Enclosed light fitting and extending circuit in a bathroom in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I've just had some electrical work completed in the bathroom; I've recently refurbished the bathroom, replacing the old electric shower with...
8K
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hi everyone, newly qualified spark here I went to a job earlier today where the fan was not running on after light had been turned off. Whilst...
