B
brizospark
I went to see a potential job today where there is two be a two floor extension built onto a medium sized detached house. Extension rooms to consist of lounge, en-suite (no electric shower), 2 x bedrooms and dressing room so potentially no serious load.
Customer has had 17th ed. DB installed previously, all looks good, only 1 spare way in board though.
Only real problem is that the DB is at the opposite end of the house to which the extension is to be built and it is a bit of a nuisance of a run to get to.
My thinking was that instead of installing larger board or installing separate board next to existing board it would be easier to run a 10/16mm cable to a sub mains board located within the extension itself. Not really seen this done in a domestic property that many times but whats you guys thinking on this, good practice? Also any advice on best way to provide o/l, rcd protection in this instance would be much appreciated as I really dont want to protect the whole new board via 1 x 30mA RCD as nuisance tripping may be a problem
Thanks in advance lads
