H
HMD
Hi all, Got some flats with office below to wire which will need CAT LD2 fire alarm system. Didnt want the hassle/Responsibly of this my self so im gna sub it. Had a local Fire alarm company price it.. was a bit pricey. Found another guy who will second fix and commission the system the thing is he uses Rafiki twinflex system. Anyone had any experience with this? Problems? is it any good? Ive seen some bad reports on a Fire installer forum.....
Thanks In advance
HMD
Keep well away from Rafiki, sensors used push in terminals, always and O/C problems.
Stick to Apollo or Hochiki from security suppliers for detection and better cheaper panels like Kentec, concept, Haes. Most panels will work on 2 wire basis, all with fulleon sounders, others with saviwire bases.
If your requested to fit Grade A then the above will comply, if Grade D then look at AICO radio link.
Thanks In advance
HMD
Hi Hefin,
We've fitted quite a few in the past, and whilst they are the cheap of the cheap, we've not had too many problems with them. We seem to get the same panel, but quite often under a different brand is something i've noticed...
We have a few Rafiki systems on our industrial Park, maintained by a really could fire company. Although we have not had much trouble, the company do not like or recommend them at all.
Wow now this shows whats going on, Rafiki only realy sold by electrical outlets.
Apollo detection aproved by full BS and EN54 cost £6, Rafiki semi £28 +
Rafiki control panel 4 zone £165 + Haes, Firesense £120
Sorry Guys would like to install the professional gear not the plastic box stuff....!
Fike (Rafiki) Alarms
Security Alarms, Door Entry and CCTV (Public)
HMD,
tazz,
