Discuss Gemini Advanced Microprocessor Control home alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Gill sans
Hi, I've just moved into a 1900 house with an existing home alarm. It says on the box that it's a Gemini Advanced Microprocessor Control. I don't have the manual but would like to change the code. The previous owners didn't know the code either.
Is there an online manual or a way of changing the code so that I can use it?
Any help is much appreciated.
you have posted in the wrong forum. let me ask mods to move it. a member goes by the name of tazz is your expert on alarms.
You can check out the manual you need from Leesparks link, if you find it hard to reset, replacing the control panel is a cheap and simple option.
Reply to Gemini Advanced Microprocessor Control home alarm in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi All, This might be a bit of an odd question, I would really appreciate your thoughts. I am trying to up-date my mum's home, before putting it...
Ok so live in 89 mobile home ugh I really need lots of work but I'm on disability and I cannot afford electrician but I've been working with all...
Hi Would really appreciate some advice on this as I have pretty limited electrical knowledge I live in a fairly new build home with 3 floors...
5K
Background is we are selling our house and moving out of state. I've been fixing big and little things and painting for several months now, as...
