J.C.E
Am a 1st year apprentice and just want to get my head around the wiring of domestic lighting...
3plate: You take a 1.5 t+e from c/u to first lighting point (L,N,E) and then loop in and out of each lighting point (hench being called loop-in method aswell as 3plate?)
then take another 1.5 t+e from the light down to a 1way switch...brown is L, blue is SL, and green/yellow E.....but this is where I get confussed with where the brown and blue goes (when the terms perminent live and switch live I hear used!)
2plate: I beleive is the same as 3plate but you take a 1.5 t+e from the c/u to the first switch and loop each switch, then take a SW up to the lighting points...correct?
Is there a more common method that is used between 3plate and 2plate, why is this?
Then I know if you want 2way lighting, its just like the 1way I explained above but with a 3core from the switch to a second switch, C-C, L1-L1, L2-L2...... correct?
Then I am pretty lost with intermediate switching?!...so any help on this is wanted!
With 3 plate you have a permanent live at the light fitting (in a connector) which comes in from the supply, powers the switch (via the brown) and loops on to the next fitting. The blue (switched live) goes back from the switch to the live at the fitting.
2 plate seems somewhat controversial on this forum - some people reckon connecting the neutral at the switch is less acceptable than connecting the live at the fitting.
The other way is to do it via a junction box so you only get one cable at each accessory (switch and fitting), although the downside is obviously you have a junction box to put somewhere that can be found at a later date.
With 2 way switching the switch cable goes to L1 and L2 instead of L1 and COM, and the 3 core just connects the like terminals on the other switch as you say.
To convert it to intermediate the L1 and L2 cables go into the terminals on the switch, which crosses them over when switched, (ie L1 switches from connecting to L1 to connecting to L2, and vice versa.) The COM cable connects in a connector behind the switch.
so your perm live,brown down to switch,live loop to next fitting, do they go into the 'LOOP' Terminal on most light fittings
and the blue SW from the switch goes into the 'LIVE' terminal in the light fitting (which also already has the brown that connects to the bulb)
correct?
and what if the light you use are downlighters, is it the same principle as above, but use a 4way junction box and wire in your live and neutral to the downlighter transformer ?
lets me just clear this up then ha!...
t+e from c/u to switch, brown-com, blue in a block, then another t&e up to downlighter tran (brown in L1 at switch and blue also in block with the other neutral)
then just L,N,E in the tran
correct ha!
I very often read on this forum of sleeving blue switch wires on a new twin+E installation
Doesn't anybody routinely use twin brown for this purpose ?
Twin brown is made with switch drops in mind, and I find it hard to understand why, when suitable cable is available, that brown/blue is used so readily :confused:
Then having to sleeve a wrong coloured cable to conform to regs :confused:
Why break regs routinely to then have to sleeve to re comply by not using the manufactured cable for the job,economically it doesn't make sense and I can think of no other reason
It does not seem right that apprentices are schooled in conveniance wiring by mentioning routinely of oversleeving blues at the switch
I want another poll :D
Personally I would prefer to be able to easily identify which is the feed and which the switched live.
Also I can't be doing faffing around with all different cable types when I don't need to.
I guessing its because you can use t&e for blue and brown and for brown and brown (with the use of brown sleeving)
but you can't use double brown t+e for blue and brown (well without sleeving it blue)
so this answers itself surely!
J.C.E
Earth
General Lighting Question
Australia
J.C.E,
kung,
