Sweet , and regardless of what switches i buy, will they fit the face plate thats already there ? .....im doing a job 70 miles from me tuesday, n didnt really take note of what i need :-/ ...dull me
if its a metal backbox/pvc back box in domestic then yolk,switches and plate should fit any one
MK metal Clad range you HAVE touse the appropriate box as the box,plate have a lip and box has flate for the yolk to fit
OLD MK the ones with metal clip for fixing switch to yold are realy hard to comeby probably better fitting a new box,yolk,switch and plate Altho if you have a small salvage electricalplace they may have bits I tend to renew if less than 4 gang over 4 gang I have a few odd switches kept from strip outs as renewing 12 switch grid for 1 faulty switch cheeses me off
Click mini grid are a doddle to fit, doesn't matter what the position of the backbox is.
Had some crabtree ones recently and the mounting yolk had tangs either side that were to wide for the metal clad box. Are these supposed to me bent back?
Grid switches
Australia
daiplayer,
simonspark,
