Why 8 CUs?Just some advice really guys, doing my 2365 hotel plan , just some advice on whether I'm on the right path or completely going southView attachment 63669
It states itWhy 8 CUs?
Cheers mate , appreciated.you need to show on drawing for question C , switched socket outlets for a kettle, TV phone charger / laptop in each room (use OSG to put minimum number of socket outlets per room depending on size, you also need to show FCU for 700W heating/cooling and FCU for bathroom towell rail.
For question D show position of DB in each room and each of the above circuits coming from this db
label each circuit (for question e) i.e R1R for room 1 ring R1H for room 1 heating R1 TR for room 1 towel rail, the R2R for roomn2 and so on.
include a legend showing symbols used
My guess is OP is going down a HMO route, each roohas it's own DB giving local resettable control over circuits, probably fed from 1 DB per floor, whith each floor DB going back to a central DB for the hotel.Bad design then one large DB for the floor?
D Show, on either electronic or hard copies of the drawing, how each circuit in the new hotelWhy 8 CUs?
What do you mean? where does it state that each room should have its own CU?i was answering the question someone asked about why all the Db,s
Probably on a spec sheet were not seeing, it may not. I've got a design project on the go for my 8202 (a mechanical workshop) and the info it's the best tbh.What do you mean? where does it state that each room should have its own CU?
the assignment spec says "What do you mean? where does it state that each room should have its own CU?
