Hi All,
I've recently installed supply for hot tub. 6mm SWA, 32A isolator on 40a RCBO. Now client wants a socket around hot tub area for using TV only. I was thinking to fit IP66 socket from isolator switch via 3A fuse spure. Isolator switch is over 2M away from hot tub. This is the easiest way I'm thinking rather then running another spur all the way through garden just for the socket for TV usage.
What's your thoughts? Can I spur off hot tub isolator switch?
Any help would be great
