Discuss Hot tub & socket as a spur in the UK Electrical Forum area at ElectriciansForums.net
Hi All,
I've recently installed supply for hot tub. 6mm SWA, 32A isolator on 40a RCBO. Now client wants a socket around hot tub area for using TV only. I was thinking to fit IP66 socket from isolator switch via 3A fuse spure. Isolator switch is over 2M away from hot tub. This is the easiest way I'm thinking rather then running another spur all the way through garden just for the socket for TV usage.
What's your thoughts? Can I spur off hot tub isolator switch?
Any help would be great
If you do that, someone will plug in an electric patio heater or other large appliance.
Fuse will blow, either resulting in you getting called back to fix broken socket or being bad mouthed to there mates about the dodgy spark that fitted a socket that only worked for a month.
Alternatively they will replace the fuse with a 13A and the tub supply will keep tripping.
Your plan is a recipe for pain in the backside.
Do it right or not at all.
Hmm? As westy implies, 32A isolator on 40A supply?
What happens if a fault (or overloaded circuit caused by adding a socket) takes the current to 33 or up to 39A??
Right on James
If the hot tub is a known fixed load less than 32A then I see no issue with that isolator being on a 40A mcb, could just loop off the live side IF it is physically large enough to do so, OR fit an adaptable box and do it in that
Reply to Hot tub & socket as a spur in the UK Electrical Forum area at ElectriciansForums.net
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
Ok i may get slated for this one but here goes; A bit of background info first. Its been a while since ive looked at my iee regs, and ive not...
Hi Guys So I've never installed a hot tub supply before so take it easy on me. I've spent a bit of time researching it myself and its a minefield...
Hi, looking for some advice, 6mm swa allready installed to a hot tub Client now wants additions and my calcs say the original swa is allready too...
Hi Customer has an extractor fan that’s inside the shower cubicle high up on the wall. The extractor fan has no form of isolation and is wired...
