Currently reading:
intruder alarm problems
Discuss intruder alarm problems in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Hi
I have been doing my first intruder alarm its a honywell accenta gen4 mini. I am only using 2x pir sensors 1 panic alarm, 1 key pad, and 1 sounder. The first pir is above the entry/exit door so I am not using any door contacts. once I set the system the pir's are picking up movement but not soundin the alarm. I think its the programing that I have wrong but dont know what to set any tips ?
When you say not sounding the alarm - can you see the LED on the PIR light up and not starting the entry/exit tone?
Might be worthwhile to perform a walk test (if not done already) to confirm the zones are going active/healthy.
Yes the led's light up during movement. Once on exit I arm the system I get the exit tone then key pad says system set but when I walk about to test the system nothing happens no alarm to alert that there is a break in. The sounder/alarm works tested it with test function. On the pirs I hae used the two connections marked relay and wired in series with other pir, there are another two that say end of line + & - that are unused.
There will be another set of terminals labelled up as "tamper" on the PIR itself, just wondering whether the EOL terminals are your alarm contacts - therefore the alarm wouldn't activate until you removed the PIR lids...
Sounds like either that or they may be programmed off of the system as you say, the Panic Button test ok?
It possible to put both PIR's on their own zone back at the panel? If left in series if someone was to break in they'd have the full entry time to fill their boots and could be half way down the road before the sounder goes off!
Have you linked out your pirs tamper switch to every pir in the panel? Have you looped linked the empty pir slots in the panel?
Yeah I have linked out the tamper controls. I have not linked out the remaining free zones in the panel. In thought I may be able to somehow only select the two zones that I am using and turn the other 6 off.
Sorry I have the tamper circuit wired in series but have it linked out just now. The sensors are wired back to the panelindividually in two separate zones. The panic button works fine, I am starting to think it may be the eon contacts in the pir I need to use and not the ones make relay.
Generally, it's not good practice to use pir's as final exit devices, much better to use contacts.
That said, check you have programmed final exit, walk through and intruder correctly, as well as ensuring there is no bells delay programmed.
Its funny that you can set the alarm system at all. Usually you need to link out the empty zones on the honywell accenta gen4.
unused zones is part of the Part Set program, It turns off zones when the system is part set.
In Full Set, all zones are active
No tazz i think your thinking of a different alarm. There is no full set or part set. You arm the zones you like. There are 3 programmes. You definitely don't link out the unused zones
Sent from my GT-I9505 using Tapatalk 4
There are 3 part sets, thats what I designed on the original accenta back in 96 at ADE. The G4 may have updated software, with a few added features. But the setup is the same. And you cannot switch out a zone, only in part set
There is no full or part set it's either set 1 2 or 3. I have no doubt you know more than me about alarms and this isn't a dick measuring competition either. I fit these and Just stating the fact
If you enter you code only, the system will time out, or exit terminate....this is full set
If you enter code, the press prog...1, 2 or 3....this will part set in one of 3 different part set suites.
Hence full set.....you wouldn`t wont to pre program omited zones in a full set. But can now see you next answer, that you could pre-program unconnected zones.....Something which was not intended, but may work, the problem would be the system wont set unless prog 1 is selected, due to open zones on code only
Hi
i think zone 1 is pre set as the entry or exit zone and this is what sets the alarm when your going out so you will need door contacts in zone 1 or unless you program zone 1 as a p.i.r zone
Note for op which may help.......if a zone is programmed as unused in 1,2,3 it will also be deleted as an entry/exit zone...
Therefore set all entry/exit or inhibited zones as used, then entry/exit or inhibited in flag menu.
Just a feeling this is your problem, after talking with onions
Reply to intruder alarm problems in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
