C
claret73
Any contributions here to Regs compliance, either deviation or all fine & dandy...
Have just fitted, along with my boss 12 Fire rated down lighters into an ongoing kitchen conversion. Original down lighters were low voltage. The ceiling had been dropped by 100mm(ish) and plaster boarded when original lighting installation was put in...
& here the problems begin:-
1/ The new downlighters are too deep for the ceiling void (no insulation, just old wallpapered ceiling with lath & plaster). So slight hole cutting required in original ceiling to get depth of housing in (10-15mm.)
2/ Feeds & switch runs taken off 3x different old ceiling rose points (3 switching points required by customer) above the false ceiling. No length on cable so terminated into a 20A JB which does become not accessible once patched. 1.5mm flex looped out & round the downlighters.
3/ Board located in the cellar with no RCD protection, (except for the shower circuit which has been taken directly off the RCD) unprotected by a 6A MCB for all Ground floor lighting.
4/ Original switch drops run behind inaccessible cupboard (height of cupboard from floor almost to ceiling). Previous Sparks have jointed a choc block at each switch, which is hanging freely but very out of reach. The switch plates are mounted directly onto cupboard fascia, cable poked through a rectangular cutout in cupboard (no enclosure & earths not connected at switches - LV Downlighters no earths, just 2core).
5/ No tests or certs carried out upon completion.
I've been looking at Building Regs as to ceiling void issue, but still getting through qualies & trawling through Regs as to RCD upgrade (with new flex install onto existing circuit), but Building Regs state Kitchens as a location, new cables etc?...all very new scenarios to me at mo.
Any answers & advice to this would be appreciated...
Cheers
Cheers
Shame your boss, boyo!
