Update for anyone who may beinterested....
Went to customer flat this morning,removed all 4 lamps and drivers (left lamps and drivers connected asthey were).
Took them straight to wholesaler.
Indecently, the drivers used were notthe same ones as my posted link, their actual spec was -
Power 3-5W
Input 200-250V AC
Output 12V DC
3 out of the 4 drivers had a smallslightly melted/distorted mark in exactly the same place on itcasing, which I pointed out to person serving me.
The lamp packaging stated 12V AC/DC onit.
The wholesaler were unable to test thelamps there and then in house, although I offered to make somethingfor them if they gave me the bits, but was declined.
No explanation could be given, but aswap out was offered, but having lost confidence in drivers and notwanting the same problem again I opted for 0-60w electronictransformers, and replacement of same lamps.
Went back re installed it all again,all working fine, my (good) customer happy with overall outcome, Iwill only go GU10 from now on I think.
Fingers crossed.
I advise that 30/50,000 hours is the quoted life of the led, not the unit as a whole. It is frequently the drivers that fail (cob technology).
Tried to return some GU10's which blew quite spectacularly apparently, the first lot of 3 went all together early summer after 3 months use blowing the fuse, the second lot followed a couple of weeks later (different fitting), again blowing the fuse. Circuit ir >299MOhms. Each blown lamp showed dead short. Each fitting was circular and open so good ventilation with the three lamp holders about 20 deg off horizontal. Was told that they were installed incorrectly as the chip cooling tubes within the bulb had to be vertical to allow for cooling. Big named brands only from then on
Well at least TLC were co-operative. On the odd occasion that I've had a problem (their fault or mine), they've always been helpful. That's one of the reasons I use their LED downlights; they're guaranteed for 5 years and I've some confidence in them being around if I ever need to take them up on it.
