Discuss LED Swapping colours when switched on/off in the Lighting Forum area at ElectriciansForums.net
coopsmind
Hi Good morning, i have just replaced 2 old dowlighters with LED ones, however, one is bright white and one is soft white(like a glow), the other problem is they swap over when switched on/off at the switch? any help greatly appreciated.
Hi all thank you for your swift replies, I have fixed the issue. The lamps are supposed to be different colours, I removed one turned the other back on and off, re-I talked the the second and the both are now the same colour.
thanks again.
With Osram Relax & Active lamps, after tens mins or so of being switched off, they revert to always starting with warm white, to avoid that situation.
Reply to LED Swapping colours when switched on/off in the Lighting Forum area at ElectriciansForums.net
Hello. I’ve been racking my brain all day with this. Here is my situation and question: I have some OEM ambient lights in my vehicle. They are...
I've fitted some led lights with power supply and mi light controller, they were working fine and all colours could be seen, then for some reason...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
