Hi,
I'm new to the forum and I am currently working on a home cinema room. I intend to use Philips Hue for the room, with 8 adjustable downlights, 4 wall lights and 2 RGB LED strips up to 10m (max with Hue.
I have pulled the ceiling down, so there is access to all cables and I will run a pelmet around the room to hide all cables.
A couple of years ago, I had work down on other areas of my house and this room was effected, the electrician on the job (bought in by the builder) had to run cables in the room (see photograph).
I have removed this wiring now, so the switch has gone, all I have is the feed into the room, connected to the feed out of the room with level wagos.
My questions are as follows;
For the lighting, I was thinking I could add additional sockets to the ring from below in the pelmet (see chase and cables to one socket), then use 13amp plugs within these sockets to each set of lights - is this realistic? For the down lights, I'd fit each with a click flow connector.
Or I was thinking I could use FCU's with a 5amp fuse for each one, so one for down lights, one for wall lights and then an additional socket for the 2 x 10m led strips (these come with a plug). Could these FCU's just be spurred from the sockets or lighting circuit?
I know I could potentially just connect them all to the lighting circuit via wagos or a junction box, but now there is not switch, if the WI-FI goes down then I won't have a way to switch them off...
