Discuss Lighting keeps blowing don't think it's wired right. The Bott blue cable is a earth cable. in the Lighting Forum area at ElectriciansForums.net
You have connected live and neutral across the switch creating a dead short assuming that doesn't link to another light. The two reds need to be kept totally separate with one of the blacks being a live switch return. No way of knowing from afar which black is this switch live return, the bare earths also need sleeving. Simple job for an electrician.
Not sure why the blue is an earth.
I assume that isn't the original connector block because it looks like it should be fixed to the back plate. What on earth did you make those holes in the plate with.
Yeah, as per Westward there's several issues with the installation that need fixing other than it being wired wrong. I'm also interested where the blue earth wire with the hi temp sleeve started out life... and who stole part of the connector block. The only way to sort it out is by testing to identify which wires are which. You're gonna need to get a sparky in for 15 mins to help you out with it.
Reply to Lighting keeps blowing don't think it's wired right. The Bott blue cable is a earth cable. in the Lighting Forum area at ElectriciansForums.net
Hello, I’m trying to change a pendent light, I’ve wired it the same as the previous light that was on there however the light is now permanently...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
