- Feb 10, 2012
- 2,264
- 2,984
- 4,688
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
- If other, please explain
- Running own small electrical company.
I have the ESC’s guide to replacing a CU where the lighting circuits have no CPC, and this says the initial approach should be to persuade the customer to upgrade the circuit to provide CPCs. If that fails, the guide then includes a risk assessment table (at the back), where it is allowed to proceed with the CU replacement if certain conditions are met (like no class 1 fittings, for example).
My question is, in practice, for those out there meeting this situation on a regular basis, what is the typical outcome (assuming the circuit meets insulation test requirements)?
Do you generally persuade the customer to upgrade the circuit (or decline to do the job)?
And if you do upgrade the circuit, do you typically rewire with new T&E, or instead fit a separate CPC and use the existing wiring?
Or are you happy to remove any class 1 fittings, place a warning notice, and proceed with the CU replacement with the existing wiring as is?
I'm thinking of an inhabited property, where costs and disruption are a concern, and all the customer originally wanted was a new CU to replace an old fuse box.
