Discuss Main fuse question. in the UK Electrical Forum area at ElectriciansForums.net
I came across this the other day and was wondering if anyone could educate me. A TNC-S supply, into a relatively new box where the neutral and earth separate, line and neutral coming out of the top of the box via a 100A fuse to the meter. So far so simple, but next to the main 100A fuse are what look like two other main fuses, with no tails coming out out them.
I didn't want to take anything apart to have a look (my isolation needs were met at the CU), but can anyone tell me what the two mystery fuses are? I've tried to attach a photo below if that's any help.
Thanks.
3 phase with 2 fuses blanks. what makes you think it's TNC-S? where is the main earthing conductor connected to supplier's facility?
They use the same stuff on the nosecone of the space shuttle, works a treat so they say. Stops anything heading to earth at high speed. ;)
My money is the install is a large old victorian house, who don't like spending money.
My money is on bobble being a Electrical Trainee lol
Reply to Main fuse question. in the UK Electrical Forum area at ElectriciansForums.net
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
Anyone come across this before? I was asked to do a Zs on a 3ph surge device; L1 was around 6 ohm, L2 & L3 around 0.11. Wired in singles from a...
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
