H
Hawk
Hi,
I was in the wholesalers last week and was getting MR16's to use as a demo for a client. I was going to get the driver to go with them, however the sales rep said that you can directly replace the current halogens with the LED's.
I did as he said and they seem to work fine. I thought that all LED's needed a constant DC supply. Is this not so?
Hi,
the led spots (gu10) have the driver in the lamp
Thats why there more expensive
Yeah but for the mr16's I would have thought that you would need to take the ac transformer out ant replace it with a dc driver. Ideally I would take the mr16's out and use GU10's, but it is a large premises with time constraints.
I have been using OLD wire wound Thorn EMI TQPS 225 transformers ( over 15 years Old ) to power my MR 16 LED`s for the past 6 years I have NEVER had any problems with wire wound tranny`s or LED`s & I can now run more lamps per tranny. It`s only the electronic controllers that I have had that failed !
On the point of GU10 (230v) versus MR 16 (12v) I find that the MR 16 (12v) last longer (in fact the only one`s that I have ever had fail, were because the electronic tranny failed, don`t know why, but the 240v GU10`s I have had many fail, presumably more electronic components to go wrong,
MR16 LED's
Hawk,
efficiencyman,
