kieran97
Trainee
Not very familiar with storage heaters
Newlec storage heater NLSH150 in clients property installed 2 years ago has gone belly up. Clients words are it got really hot so they switched it off and it wouldn't heat back up the day after. My obvious thought was a thermal cut out but I've had a look inside and there doesn't seem to be any sort of cut out inside the unit That I can see.
Other heaters work fine, E7 supply. Switching devices all OK. Elements are OK.
Is anyone familiar with these that can give some advice. I've tried looking online but there's little to no information on the new heaters and the brand doesn't seem to have a support line. Or if there's a cutout of some sort I've missed or isn't resetable but I find that hard to believe with today's tech
Hopefully it hasn't just died in 2 years of service
Appreciate any guidance, cheers
From the front cover of the manual: Newlec Helpline: 0800 783 6909
I think they're all made by dimplex. I haven't done much fault-finding on modern storage heaters, but for older ones I usually open up, take out some bricks, and wire it up to a 24 hour supply. Then I can see if the elements are heating up and carry out live tests. The problem may be upstream, for example a burnt out connection at a switch etc.
kieran97
Trainee
Leicester
United Kingdom
Electrical Engineer (Qualified)
Newlec storage NLSH150 heater any info
kieran97,
Pretty Mouth,
