timhoward
Broke Internet
Supporter
I accept this is an unusual post!
This clock has been in a family since early 1930's, the owners grandfather acquired it and fitted it for his mother. (Folk law is that it was one of the first electric clocks in Coventry, but who knows.)
I've been asked if it could be put into use again. As I rather like mad projects I said I'd have a look at it.
I've tested the coil resistance, and IR tested both sides of coil to metal case and was satisfied that it wasn't an instant electrical death trap. But it didn't work, even manually trying to get the motor to take. The motor wasn't moving freely so I've had it largely to bits, cleaned and oiled what I could, got it back together again (that is the truly amazing bit) and now to my delight it actually works.
Therefore the question is, what is the best was to connect a metal cased simple clock to a modern supply. Clock points are not really in abundance in houses these days.
Could it be as simple as a suitable grommet, flex, and plug with 1 amp fuse, and would you find a way to earth the casing? Other suggestions most welcome.
I'd personally got down the route of earthing the casing and feeding from a low amp fuse. If you could get a cable gland that would be ideal, but it doesn't look easy. Along as the connections Re covered and there is some method of securing the outer sheath then I can't seeca problem.
Nice to see it being kept in use.
Nice clock, there often isn't much in the way of cord grips on old clocks as they mount on the wall usually to a clock point very near and are not likely to get disturbed much. Careful with the oiling, less is definitely more when it comes to clocks.
This will probably be the next clock I do, purchased by SWEB in 1970 for use in a meter testing station at a cost of £86/13/3. Despatched by Landis & Gyr in 7-8 months after receipt of order...
Very nice. The clock face has actually got quite a modern look.
What about using an isolating transformer? Perhaps salvaging one from a shavers socket and fitting it in a adaptable box.
It’s so funny that I’d just been hunting in my scrap box for a shaver socket that I haven’t already misused….
But not for this project. My main concern would be the transformer getting warm inside a box.
If it was for my own shed it’s one thing, but this is for a customer so I should avoid creative hacks! I like your thinking though!
timhoward
Broke Internet
Supporter
Oswestry
Old Electric clock, best/safest way to connect?
timhoward,
ipf,
