Can anyone perhaps give me some direction here as i don't have too much experience with heating and this is baffling me somewhat :rolleyes2: .
I've got 4 panel heaters, two of which are fan assisted. The latter two which are in the lounge & dining room can't be switched off. the other two, in the bedroom & hall won't switch on.
The heaters run from separate mcb's via a 230v contactor to switches next to the fans.
The heaters in the lounge & dining room also run from separate mcb's labelled 'fans' which go via fused spurs next to these heaters.
The contactor switch, which i can't locate the source for, assumingly runs from the fire system?
When i first looked at the contactor i was getting supply voltage but no load voltage from it. After replacing the contactor I am now getting 230v from the load side, but only for the bedroom & hall circuits. The lounge/dining room loads are 50v
The fan fused switches have power to them but none of the heater switches are receiving power (even though 230v is leaving the contactor/ccu for two of them!)
Below is a diagram of my interpretation of the set-up. (note. the previous owner was evicted so i'm not ruling out sabotage lol)
