telectrix
Mentor
Supporter
Sep 5, 2010
71,498
72,015
18,688
78
cheshire/staffordshire
Business Name
Telectrix
brief idea of set-up... bedroom extension atop attached garage. obviously needed planning permission. builder ( or whoever worked for him ) extended house ring final 2 S/O in new bedroom, 3 S/O in garage. wired in 1.5mm 3core with yellow used as cpc. actual cpc connected randomly to back boxes, no continuity or sleeving. ring continuity broken as it was bodge connected in RFC. stand alone RCD fed with a 13A plug top and T/E in plug to feed an outside S/O. how the hell did this pass BC inspection?
Reactions: 1 person
Nepotism ..............back hander ...................builder doing the BC home and families homes for nothing .......the choice is yours mate
You know they have no interest in the electrical work
You know they dont have the technical knowledge for inspecting the work. even if they did. by some remote possibility, take any interest
You know it goes on
You know it will continue to go on
Tel, you know the answer
Reactions: 2 people
You could wire it all in bell wire, clip it all to the walls with masking tape, and incorporate any other kind of bodge going. As long as the Building Inspector gets his bit of paper he couldn't give a ----.
Cheers...........Howard
Reactions: 1 person
telectrix
Mentor
Supporter
Business Name
Telectrix
passed by building control
Electrician Talk
telectrix,
Octopus,
