So the earth wire is the yellow one with hints of green on the wire then. And i just stick that between blue/brown?it's a class II fitting. does not need earthing. see terminal block bottom corner of instriuctions. brown to brown(L), blue to blue (N). park earth wire in centre terminal.
I mean i would put the earth wire next to blue and brown? So it would be 3 in a row for the wires on the same terminal. Or would i put it on the other side of the terminal in the places i'd put the blue/brown.
Can't deny that it looks like a bog?
First sight I thought that might have been Tony's all singing all dancing bog from way back.
