I mean i would put the earth wire next to blue and brown? So it would be 3 in a row for the wires on the same terminal. Or would i put it on the other side of the terminal in the places i'd put the blue/brown.
See telectrix post above , connect as per instructions
Reactions: loz2754
Managed to put it up this afternoon. It came on for about 20 seconds or something, then it clicked on and off a few times then it went off. Even waving in front of the sensor didn't make it come back on again, but i am not sure whether that is due to it being broad daylight or what. In a few hours i'll find out, because i've wired it up correctly. During the fiddling process of putting the wires in/putting the front of the lamp on a brown wire came out, which i knew was the case but my family member who helped me said it hadn't happened so i took it apart again and the brown wire had come loose (after putting the wire back it stayed on, then clicked 3/4 times on and off then it went off again)?. In just under 3 hours i'll see if it comes on during darkness when i walk past it.
Email
Time zone
Last seen
PIR sensor light installation help
Lighting Forum
Miguel_92,
Miguel_92,
