Guest viewing limit reached
Hello All,
I need help with powering a garden water pump. I need a transformer but don't know which one. Please check the picture.
Any advice would be appreciated. Thank you.
I'd suggest if it's a permanent feature then a 12V AC transformer and a proper protected joint (no plugs) would be the most efficient option.
That looks new - why didn't the transformer come with it?
Probably because it's Chinese - if they don't send the mains then they don't have to make sure it conforms!
As an Amazon Associate we earn from qualifying purchases.
Can you post a pic of the connector on the end of the cable, if it has one.
As @telectrix says, look for a 240V/12V A.C. power supply capable of 3A.
Londom
Business Name
None
Please help with powering garden pool filter
Lukymorz,
telectrix,
