Discuss Power tool connected to a socket doesn't activate when power switch depressed in the UK Electrical Forum area at ElectriciansForums.net
Diyer008
Power saw connected to a socket doesn't activate when power switch depressed, but it turns on the light fixture in ceiling nearby while power button is depressed. Can someone point me in the right direction on how to correct this problem. Please let me know if you need any additional details as I'm pretty new to this. Thank you ahead for any help or tips.
Sounds like the wiring at the outlet is incorrect. Has it ever worked correctly?
If it is a replacement the combo can act in a couple of ways. The switch controls the receptacle and no light or the switch controls a light and the receptacle generally remains permanently on so it is possible the switch is operating correctly and the hot link to the receptacle has been removed. Would need to know the type of outlet and whether it is existing or a replacement.
Two possibilities:
The receptacle is incorrectly connected in series with the light (and if the light works from the switch, the receptacle is in parallel with that) instead of being connected directly to the power feed. This has probably never worked correctly since installation.
Or, much less likely, it's a multi-wire branch circuit (light on one hot leg, receptacle on the other) with a broken neutral, which puts the light and appliance in series across 240 volts. The fact the bulb didn't go pop suggests this is not the problem (tungsten would have blown immediately but LED might survive briefly). This could have worked correctly in the past until the neutral became disconnected.
We would need to see the wiring at the receptacle to make any progress. If it is incorrect, it suggests that whoever installed it didn't know what they were doing, therefore there might be other problems.
it did work correctly initially. We disconnected a couple outlet and switch to break down wall. After we rewired the outlet gave problem. We have yet to reconnect switch. Will try that and report back to see what effect it has.
I strongly suspect you have made a mistake when you did the wiring mods.
Reply to Power tool connected to a socket doesn't activate when power switch depressed in the UK Electrical Forum area at ElectriciansForums.net
Hello all, I'm replacing a 3-bulb spotlight with a standard BG ceiling rose but upon connecting, the light won't turn on; the problem is, I can't...
6K
Info: Located in US I have a 48” T8 fixture that I recently added LED’s by removing the ballast and wiring directly. After doing so when hanging...
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
Hi guys, I have recently encountered that my circuit breaker for the upstairs lights keeps tripping. I flick it back on and immediately it trips...
