Currently reading:
Pulling live meter tails from isolater switch in consumer unit
Discuss Pulling live meter tails from isolater switch in consumer unit in the UK Electrical Forum area at ElectriciansForums.net
3435hobiton
Hi, could someone advise me of the safest procedure when pulling live meter tails from the isolator switch at the consumer unit. I know about switching off the main switch to take out the load, but will not be cutting the seal and pulling the fuse from the cut-out. On this occasion I need to pull out the live first... connect to a Henley block and then the neutral and do the same. When reconnecting I will connect the neutral first and then the live. I was wondering if anybody could offer any helpful advise that I may have overlooked.
Regards Paul
An exposed live part, such as with a missing DB blank, is an immediate danger.
Playing devil's advocate.
It's not immediately dangerous if someone doesn't stick their fingers in. "Most" people wouldn't think of sticking their fingers in.
An ES lamp in a holder without a big shroud will have an exposed live shell - waiting to zap people who would not expect it to be live. So why isn't that immediately dangerous - it doesn't need a fault to be live. And it will still be live when switched off at the wall if it's a single pole switch.
.C1, C2, C3 does not represent levels of how bad you think something is, they are codes with clearly defined meanings.
In theory - but look at how many "discussions" we have here about coding !
Yes everything connected to the neutral bar at the DB will be at line voltage, but it will all be behind covers which needs to be deliberately removed before being touched.
AND everything in the whole installation connected to neutral. Like ES lamp caps, and the pins in BC lampholders. Even when a reasonable user might expect things to be off because "switched off".
It is immediately dangerous because someone can touch a live part without a fault occurring, cover being removed etc.
The immediate danger is that a person could make contact with a live part.
Yes it will, but I don't see how that is relevant to the debate.
The debate is around the advice that reverse polarity at the incoming supply is a C1 but elsewhere in the installation is a C2.
The case of the exposed ES lamp cap would make it a C1 regardless of where the reverse polarity is in the installation.
It is immediately dangerous, I have not suggested it isn't.
I am not suggesting that a reversed polarity fault can't be immediately dangerous, I am saying that it is not always immediately dangerous.
Yes there are many discussions, that doesn't change the fact that the codes are clearly defined. The number of discussions, and the content of many of them, show something about the knowledge and understanding of some of the people carrying out EICRs and highlight the problems with some of the published guidance.
The pins in BC lamp holders are always there regardless of the polarity and are always a danger. The BC lampholder is only allowed because there is no reasonable way to get rid of it, if a lampholder with exposed pins like that was invented today it would never be allowed.
New posts
Reply to Pulling live meter tails from isolater switch in consumer unit in the UK Electrical Forum area at ElectriciansForums.net
