Discuss Putting light fixture with 2 bulbs on a single bulb ceiling outlet in the Lighting Forum area at ElectriciansForums.net
farmerfa
Hi all. We have a light fixture that has single bulb fixture on ceiling.
I want to change this to a 2 bulb fixture. Is this just as simple as removing the existing fixture and wiring the 3 into the double bulb one?
I see black/red/greenyellow wires currently attached.
Not so good with electrical things and still want to do DIY for simple things like this. Please help. Thank you.
Take a picture before you remove any wiring. Make sure you do safe isolation.
Would be better if you got someone in though, it'd be 50 quid and 10 minutes of their time to do it properly.
And yes, amount of bulbs doesn't matter.
More like 85 Aussie dollars for the OP
Reply to Putting light fixture with 2 bulbs on a single bulb ceiling outlet in the Lighting Forum area at ElectriciansForums.net
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
I made a DIY light fixture by putting some cut-to-size LED strips in an aluminum housing connecting them to a Mean Well DC power supply with a...
I'm encountering a problem with the lighting in my kitchen. I reside in an apartment that has a light fixture utilizing 2 T8 fluorescent bulbs...
Ceiling closet light blew out. Checked bulb. Bulb good. Have 120v leaving light switch. Removed fixture. Have 120v at wires in ceiling when switch...
Good Morning, I've used this forum for advice many times but this is my first time posting so I hope that this community can help! We're...
