Disconnecting the circuit and doing full tests is the job tomorrow.
Just thinking - the main feed to the house is through the cellars of the two adjoining terrace houses. If they disconnected the earth could that cause the problems?
I would have thought though that there would still have to be a fault in my wiring to cause the symptoms.
Who knows, because until you get your test kit out we haven't got a bloody clue what's actually do we?
so do us a favour and reply when you have some results if you have been unable to find it.
What sort of spark were you?
The wiring in the house is split into separate circuits each with their own RCBO for
3 for lighting (separate for ground floor; upper floor; and basement)
3 for power (again as above)
1 for cooker
1 for shower
2 for fridge/freezers
The problem exists only on the ground floor power circuit.
Whenever the vacuum (two core) is switched on in any socket, the RCBO trips. It's not the vacuum as it dos not happen on the upper floor. I have even tried an angle grinder- thinking maybe induction issues - but it does no trip.
Occasionally the circuit trips on its own, or if the computer is switched on.
I've checked all the sockets for damaged or trapped wiring, but nothing found.
Does anyone have any suggestions please.
Peter
So its when the vacuum is switched on???
But its not the vacuum???
Or is it the computer??
Heres one how about the hoover IS faulty and another bit of equipment and the other rcbos are not functioning correctly ive came across quite a few rcbos that dont work properly and have been sent back to MF.
Bloody amateurs! It's obviously a fault on the kettle, everyone puts the kettle on to boil while they're doing a bit of vacuuming and no one ever suspects their good friend the kettle because it never lets them down.
Well, think again because it's no friend. It's there in the corner just waiting to scald you and one day it'll take its' chance.
Don't say I didn't warn you!
one of these maybe:
faulty rcbo I reckon! no appliance consistently trips the rcbo and dont trip other rcbos! disconnect the circuit and turn on rcbo and see if it still trips!!
I find more rcbos FAILING to trip than faulty tripping without cause, purely due to the way they are made.
I've encountered exactly this before. Turned out in the end to be damp in a light fitting!
To those who are saying 'faulty appliance'. It was initially thought to be vacuum, but as I said later --
I have unplugged or switched off (where via switched spur outlet - DP) all items on the same RCBO. And the RCBO stays on for about 2 mins or little more then trips. Without doing anything. (Yes even the boiler and kettle are off)
So its not the kettle or the vac.
I'll do some more testing in the morning.
Peter
Personally I don't think you deserved some of the responses you got.
If you've been out of the game for a few years you probably don't have your fault finding head on.
You have to bear in mind that a lot of new posters on here are DIY or chancers and there are a lot of folks sick of it.
As has been said before if you are still struggling with it after testing post up what tests and results and then you will most likely get some helpful responses.
There will probably still be some sarcy remarks but that is the nature of this forum.
