Discuss Regs Help Please in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
C
chappy2000
Hi all,
Hoping someone can help with clarification on a reg(s). Recently installed a shower surface trunking and went back to test and connect at cu today after the plumber had been. Im really p****d off as the plumber couldn't be bothered to take his pipe down the shower and use the bottom or side entry he has cut into my trunking with a compression elbow and has passed onto the client that I need to replace the trunking for larger as now the lid won't fit on with this compression. Now I'm looking for some back up from the regs ( as common sense is clearly not enough ) now i was thinking electrical seperation but as its a cold water feed I believe there is a section referring to if its not going to damage the cable under normal use then its fine. Also with his pipe now entering the shower its a real tight squeeze and the cable has been marked where its pushing so tight onto the entry hole.
Sorry for such a ramble about a pretty small issue I'm just so annoyed and don't want to give him any way to wriggle out of it as I know he will. Thanks.
2x1 trunking simples easy fit one 15mm pipe and one 10mm t + e well thats what i use saves on bickering and unexpected surprises
if the cable has been squashed, then detrimental influences comes into play. find a plumber with some sense ( might take a while).
bend the plumbers pipe out of your trunking and tell him to get his own joking of course go back make good and charge the customer again oh and if the customer moans tell them to charge it to the plumber
Reply to Regs Help Please in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi, I've just had some electrical work completed in the bathroom; I've recently refurbished the bathroom, replacing the old electric shower with...
8K
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
Hi, I have a client with a small caravan site, approx 5 hookups. His old toilet block was nothing much more than an old shed. He's now 'upgraded'...
Hey all, Ive been in and out of a huge house rewiring as the renovate it for a year of so. Every is thing done and dusted except the downstairs...
This isn't really an electrical issue as such but I know you guys are pretty tech savvy and familiar with all the latest and greatest...
