C
chappy2000
Hi all,
Hoping someone can help with clarification on a reg(s). Recently installed a shower surface trunking and went back to test and connect at cu today after the plumber had been. Im really p****d off as the plumber couldn't be bothered to take his pipe down the shower and use the bottom or side entry he has cut into my trunking with a compression elbow and has passed onto the client that I need to replace the trunking for larger as now the lid won't fit on with this compression. Now I'm looking for some back up from the regs ( as common sense is clearly not enough ) now i was thinking electrical seperation but as its a cold water feed I believe there is a section referring to if its not going to damage the cable under normal use then its fine. Also with his pipe now entering the shower its a real tight squeeze and the cable has been marked where its pushing so tight onto the entry hole.
Sorry for such a ramble about a pretty small issue I'm just so annoyed and don't want to give him any way to wriggle out of it as I know he will. Thanks.
