Discuss Ring Final Circuit - spurs only in the UK Electrical Forum area at ElectriciansForums.net
Yep. A socket is a socket.Yes.
Unless it's a socket if it is why not call it a socket?
You must have been.So, a 110v yellow socket is the same as a blue 230v commando socket which therefore is also the same as a bs1363? Bugger, I've been doing it wrong for so long.....
The back box is a dual backbox slightly wider than a standard double back box allowing 2 single face plates to be fitted, be they single socket outlet, flex outlet or FCU.Fused spur and a socket in one double never seen one of them
Or you could use one of theseThe back box is a dual backbox slightly wider than a standard double back box allowing 2 single face plates to be fitted, be they single socket outlet, flex outlet or FCU.
Reply to Ring Final Circuit - spurs only in the UK Electrical Forum area at ElectriciansForums.net
