Guest viewing is limited
B
besenzig
Hi
I have a robin KMP5406DL RCD tester which has a pulg lead to test socket circuits. How would I test
a radial circuit on a RCBO with this tester.
Could I use the 3 leads cable supplied with the KMP4120 loop tester
on the RCD tester? If so where should I test CU or end of circuit and how would connect this lead to the RCBO circuit.
Thank you
Hi
Thank you
Oh Jesus! glad I live over 200 miles away from London
Robin RCD tester
besenzig,
DHES,
