Discuss Smart meters cause soaring bills True or False in the UK Electrical Forum area at ElectriciansForums.net
Not had any problems since the pass.Do smart meters cause soaring bills due to inrush currents recorded digitally? Low power factor equipment may cause this???? What is the hive mind conclusion?
Higher smart meter bills are almost certainly due to the variable tariff the energy suppliers provide as the standard recommended option. That's why they try to get you to agree to 1/2 hour meter readings. The half hour readings option was helpfully bordered in green in all the annoying letters I get from my supplier. Fark you SSE.Do smart meters cause soaring bills due to inrush currents recorded digitally? Low power factor equipment may cause this???? What is the hive mind conclusion?
Yes the half hour readings allow the supplier to work out when you use most electricity, morning shower, evening cooking etc. the variable tariff allows them to set the high usage times to a peak rate and the low use times such as at night or when you are at work to a low rate.Please excuse my ignorance but what difference would it make as to if its a half hour reading or 1 a day reading? At the end of the day you have still used the same amount of electricity. Or have I miss-read something?
But by agreeing to have a smart meter you accept the smart meter terms and conditions which clearly stats this type of per household adjustable tariff. One of the reasons I don't have a smart meter!they wouldn't be able to do individual tariffs per household as that would be discrimination.
At the moment, yes, but ultimately it will become a much more sophisticated version of Economy 7, with multiple tariffs, and hopefully smart appliances will detect these tariffs, and things that can, will use power when it is cheapest.The only advantage to the user is controlling the amount of energy used with the aid of the IHD, when folk see it plunging into the red they think wow lets knock the usage down, also it does away with estimated billing.
The advantage to the energy supplier no need for meter readers.
wHATTTTT! How? I pay 130 pm and 250 when with British gas. I want some of what you are doing. Oh btw I am with octopus. Feel a bit guilty as I have been known to eat a little here and there.£10 a month.
I didn't really know much about the things. I was quite shocked by some of the conditions listed. I forget what the other concerning things were, it was several months ago I read them.Not wanting a smart meter I have never looked into the T&C and I didn't know about the adjustable tariff.
I like your optimismAt the moment, yes, but ultimately it will become a much more sophisticated version of Economy 7, with multiple tariffs, and hopefully smart appliances will detect these tariffs, and things that can, will use power when it is cheapest.
Advantage to the supplier is that it will smooth out peaks and troughs in demand, or more likely, match the demand to when there is available renewable energy.
They key @Vortigern is refer all your friends and family. You get £50 they get £50.wHATTTTT! How? I pay 130 pm and 250 when with British gas. I want some of what you are doing. Oh btw I am with octopus. Feel a bit guilty as I have been known to eat a little here and there.
Reply to Smart meters cause soaring bills True or False in the UK Electrical Forum area at ElectriciansForums.net
