W
woodsta
I have been given a spec on a job from a builder and it has been suggested in the spec that we should use a 100 amp supply which is currently feeding 1 DB to split it to supply 3 DB's. So using the supply to go into a sub main board. Off this they want to supply 2 flats and a communal mobility charger room Db. each flat will have a cooker and hob supply and elec showers and the charger room will have approximately 15 sockets. I'm thinking the flats would need there own independent supplies.
A 100A 3phase head would be more ideal then you could install a BNO network and have the flats and landlords seperatly metered. I would raise your concerns with the builder over the spec and go from there.
thanks Lee.No worries regarding metering as its a care home but forgot to mention its a single phase supply using 2 core 25mm swa. £phase would have been ideal!!!
Well off the top of my head I get a max demand that exceeds that supply in strict terms, any chance of a 3 phase supply?
Are they having baths installed if so there must be hot water availability which the showers could be connected to?
for a 2 core its 146Amps but have to allow for volt drop also but its only a 30m run to main sub main panel. If they will let us clip direct (which I doubt) I would put three phase supply in. I guess we go back to the drawing board and the builder
I don't think that's woodsta's point.
100A just isn't enough, period.
splitting a 100 amp supply for 3 DB's
woodsta,
LeeH,
