Hello all. I have visited a domestic property with two consumer units, one downstairs and then a separate one for upstairs. The upstairs is fed by a 16mm twin and earth and the downstairs is fed by 25mm tails. The cu downstairs is a duel RCD. The question I want to ask is, since the cable feeding upstairs is buried, I was planning to install the sub main directly into downstairs consumer unit. However. The problem is the issue with conflicting RCD. I don't want nuisance tripping occuring since the RCD downstairs is only rated 30ma. I was under the impression that time delay rcbo were easily available but after a bit of shopping around, it's not the case. This was my initial idea on how to resolve the issue. Thank you in advance
