Discuss SWITCHED DOUBLE SOCKET HELP?! - MUCH APPRECIATED in the UK Electrical Forum area at ElectriciansForums.net
Tbh callum, its a better job than some who i know would do. I’ve some drill a hole through worktop and plug the lights into a socket and use that as there switching
Not quite what i'm trying to accomplish though is it. I know this is a possibility which can be done. Just trying to work out the best way to go about it. If you have any logical idea on how would be best to accomplish what i'm trying to do then please step in with your advice. As currently i'm hearing a lot of 'dont do its' but no alternatives being offered.
I wouldn’t recommend this at all. You are mixing 2 circuits I.e. your lighting circuit and your socket circuit in 1 switch. It is unlikely but not impossible where you could have a fault whereby your lighting circuit ends up protected by a 32A MCB which would not protect a 1.5mm cable. It is just bad practice and as someone else said could be a mine field for someone else fault finding in the future. There will be much better ways of doing this.
Completely understand what your saying, however, what could be an alternative to accomplish this?
the op is not listening.
Reply to SWITCHED DOUBLE SOCKET HELP?! - MUCH APPRECIATED in the UK Electrical Forum area at ElectriciansForums.net
Double wall socket switch won't switch off. It just flips back to on. The left side one is fine. It used to do this 3 years ago then was working...
i have just started my course as a trainee electrician...some advice on the following will be appreciated: I have a spare 16 and 32A MCB (RCD...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
