Morning.
I have been asked to finish a job to connect a 1.5mm SWA cable into a DB which feeds a post to power some security cameras.
The SWA cable enters the building and into some metal trunking. The trunking butts up to the DB and there is a large entry hole into the DB through which the existing cables go. See picture.
How is it best to terminate the SWA? Is it best to bring the cable out of the trunking through a PVC gland and then terminate into the DB using the usual SWA terminating gland on the DB? Is there a better solution?
Obviously it would look better if I didn't need to bring the cable out of the trunking and back into the DB..
