C
Chrisdisco
Hi everyone
I have a question regarding an old tester I have purchased. The tester is a Seaward 500H, quite an old tester I know. My question is how do I test IEC leads and extention leads? It doesn't have a IEC socket so I guess I have to create an adapter?
Any help or advice is greatfully received.
Chris
Yes you will need an adaptor.
Try forum sponsors "Test Meter" - they should be able to help you
Testing of cables requires both ends of the cable to be plugged into the tester.
There doesn't appear to be any connector apart from the usual 13A socket outlet and earth test lead connector on this tester so I don't believe that it has the ability to fully test IEC leads and extension leads.
You can test them as a class I appliance for insulation resistance, and you could make up an adaptor to allow testing of the continuity of the earth core, but it won't check the polarity of line and neutral.
you wil need another tester with continuity function to test live and neutral to measure resistance between both ends of the cable.
can do it manually but time consuming, is possible to rig up an adaptor with some double pole switches and test sockets that will plug into the tester.
Thanks everyone for your replies. I must admit, this tester is a lot more basic than the supernova I was able to lend for the last few years!
I have a had a look at the instructions and the tester will preform the following tests:-
Protective earth
Insulation
Leakage
I have made an adapter which is a male IEC plug with just the earth wire coming out. The insulation and leakage tests work fine and achieve the expected results. The protective earth test for both + and - are reading results at around 0.295 ohms which brings the red light on as a fail. I have tried a couple of 2 meter leads and this is the same for both. I have a short 0.5 meter lead and when testing that, I get 0.195. It's could be that the adapter I made is rubbish and have found a professional one on the net which should turn up this week.
So I don't know if I'm missing something?
I am uncertain what you're trying to achieve here. Can you clarify what is meant by "The protective earth test for both + and -"
Email
Time zone
Last seen
Testing IEC leads
Electrical Testing & PAT Testing Forum
Chrisdisco,
telectrix,
