L
linux44
Hi all,
I am trying to change my honeywell analog thermostat with a wireless thermostat .
My current thermostat is
T6360 Room Thermostat - Honeywell UK Heating Controls
my new thermostat is salus rt500rf
RT500RF - Wireless Programmable Room Thermostat - 868MHz
blow is the diagram of my old (current thermostat )
1 or brown is live as tested with my multimeter
2 and 3 are both neutral and can't work out the difference between them . when I put the multi meter probe on 2 the voltage is higher than it is with 3 . on three it is around 200 and on 2 around 230.
From the diagram , I think the coil symbol and the rectangle symbol between 2 and 3 means resistor , right ?
The new thermostat has a relay and then the wireless thermostat
now the relay , I have Live , Neutral, Normally open and Com(Linked live feed) connection ports.
The picture from the manual is below.
Now I connected the live to live on the new relay and pin 2 from the old thermostat to neutral and left 3 out . The relay came on but was not sending any signal to the boiler.
I swapped 2 with 3 so this time I have 1 (live ) and 3 neutral connected with 2 left alone . The boiler came on permanently and the thermostat was ignored.
what do I need to do ?
Many thanks
Many thanks
