P
Peter Woodford
Guys,
looked into a tt system today and found at main board which is rcd protected a 10mm armoured going to a board which is in the workshop then feeding circuits in there. The board in the workshop has a earth rod in the ground however the supply to the workshop from the board in the house does not have a earth supply running into the workshop from the main board am i right in saying that the cable from the board to the workshop should also have a separate earth ran aswell to protect the cable
thanks in advance
If it's an armoured cable, then providing its glanded and terminated correctly at the supply end, the armouring will do the job of clearing a fault that may occur before the shed cu.
its just been chucked in by the look of it will gland the correct way when i go back to the house and check thanks
tt supply to work shop
Peter Woodford,
Peter Woodford,
