Discuss Warning Labels inside consumer unit lid in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
They often fail to meet the required times when testing for an EICR or alteration/addition job due to not being operated for years, but after a couple of 'trips' they're generally fine again .
Really.........................................?
I simply don't agree.
Well surely it stands to reason that at the time of the change most Electricians would have been aware of it, but say in 20 or 30 years time many of the new breed will never have been come across red/yellow/blue and black cables.
But if they are competent sparks the would check that the "odd" red cables are live, and the black ones neutral.
Next the IET will be getting us to code all red and black cables C3!
I still have some red sleeving left and use it on unmarked black switch wires whenever I come across them, it's annoying to find brown sleeve on both red and black on older wiring inside switches imo. :)
But if they are competent sparks the would check that the "odd" red cables are live (sic), and the black ones neutral.
It's not as straightforward with a three-phase installation though where blue could be either L3 or neutral and black could be either L2 or neutral. It doesn't seem entirely unreasonable to warn people to verify what the conductors actually are.
Reply to Warning Labels inside consumer unit lid in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have a doorbell I want to install. The issue is the 16v transformer is designed to sit on a DIN rail. I have a 10 way 17th edition BG Nexus...
I was just googling for skeleton boards after reading the last thread and various pictures of consumer units popped up, some wired terribly and...
Hi, I'm getting conflicting stories about this, I wonder if someone could put this to bed once and for all. I'm replacing a consumer unit in the...
4K
...and why would I want to do that ? Well, I'm faced with a real botch job of a consumer unit. Essentially this is a "new" consumer unit only put...
9K
It's been asked a thousand times I know, but nothing quite matches what I have to work with. Ok, it's a 1950's ish house, 2 bed terrace, so very...
4K
