E
electricshock
Machine uses total power of 75kva. 22kw. 3 phase.
What size cable will I need for this machine?
Discuss What size cable do I need? in the Commercial Electrical Advice area at ElectriciansForums.net
If it is folded in half it is half the length when it is run out straightWhat length is a piece of string ?
We need much much more, think about it and repostMachine uses total power of 75kva. 22kw. 3 phase.
It will be about 35 meters length clipped direct on wall
You got bigger problems here than cable size, with a P.F. of 0.3 you're gonna want to work out how you go about correcting that first!
I haven't done machine this big before so I'm kinda clueless
I hope you have your tin hat on
I need to get one.
Looks like I won't get any help here. Thanks anyway
Does Tidy rinse it out for you?
It would be great if someone can do everything for me.
Haven't done this kind of work and calculations. That's why I don't have a clue.
Il get my books out.
If you are/were an apprentice trained spark you should be able to do this even if it means digging as far down as your toes to remember how.
If you are not a spark then you are asking for info which will take work away from a spark.
The best way to get help on here is to try yourself and post the results. Strangely, you will get more help if you get it obviously wrong.
Meantime for everybody to prepare to help you you need to provide more info. Ambient temp., ze, type of proposed cable etc, etc.
Boydy
And if he is a Electrical Trainee the formula should still be on his desk with the ink still fresh
Reply to What size cable do I need? in the Commercial Electrical Advice area at ElectriciansForums.net
