I've never worked on consumer units but always wondered how the mains cable is wired into the main switch of the board i.e. is this Live when being wired in?
Also, in terms of working in the board, I assume once the main switch is set to off and you have checked with a 2 pole tester, you are safe to work within this?
Definitely not planning to do this myself!
No.
With experience, yes. You have to be aware of the presence of live parts. Earth wires can be particularly dangerous when installing.
Perhaps "huge" was an exaggeration but I have been quoted £500 for the Dual RCD board. Includes materials and fitting. £620 for RCBO's.
This all RCBO versus split load RCD keeps coming up on here. I wired my place just under forty years ago with a three RCD board and all 12 circuits through one or other of them. All RCDs are in full working order, but, apart from when I've been playing and managed to short a neutral and earth together, the only times I've ever had one trip is when an immersion heater element failed and the dishwasher sprung a water leak.
The inconvenience of RCDs is much overstated IMHO.
